ECU problem? Help!
Old Jan 8, 2005 | 03:18 PM
green100's Avatar
Default ECU problem? Help!
The oil sensor came on w/ check engine light and the tachometer stoped working. I took it to the shop and they replaced the oil sensor that seems to take care of that problem. However, the tachometer is still not working and the transmission doesn't seem to shift pass 3rd or 4th gear because I hear the engine rev up quite a bit. They told me I have a bad ECU that's conttrolling and causing these problem. Is this correct? Can some one please help? Thanks a lot!
Old Jan 9, 2005 | 12:57 AM
snowman '92 100's Avatar
What year is your car? You need to get codes read if it's >= 94 IIRC.
Old Jan 10, 2005 | 12:35 PM
green100's Avatar
Default Re: What year is your car? You need to get codes read if it's >= 94 IIRC.
1994 100CS V6 2.8. After I posted my message a couple days ago, the tachometer suddenly decided to work again but I can see the check engine light flips on/off occassionally. It comes on briefly a few times when I start the engine but it goes off after that. One thing I've noticed during driving sometimes it feels like it's halting and coming back right away. Does this seem to be the ECU related? Thanks!
19khz
11
Feb 26, 2010 08:13 AM
Chachora103
Texas Discussion
Nov 14, 2006 06:01 PM
Chachora103
Nov 14, 2006 03:06 PM
UrSoccer_mobileĀ®
Audi Original "S" Cars
19
May 27, 2004 11:43 AM
M3iRiSH
Nov 19, 2001 08:58 PM
