ISV???
Any help out there??
Oh and if I turn it off it needs re-connecting to start!!
I think I will try and get a new ISV as this has probably done 120K
Check that this microswitch opens as soon as the trottle flap starts to open. It helps to lubricate the throttle flap spindle as well with something like WD40.
You are also on the right track by just giving the valve a good clean but clean the throttle flap and the air-bleed hole as well. Count how many turns to screw the adjuster in, then take it out and spray WD40 directly down the hole, then blow dwon it with a tube or air-line then put it back to the same position.
I have found a way to drive through this missing and cutting out that, so far has worked. If when it occurs, I straight away(within a few seconds) back off the gas and let it overun for say 500 yards, the engine pulls itself together and runs right again!!! If I try to make it keep going, it gets worse and worse until the engine is barely able to pull the car along. Does this point towards anything?
Thanks
If it has a dizzy, then I would check the condition of the cap and the rotor arm, maybe renew both just as a matter of course.
I could be the ignition coil or the balast resistor which I think it may have. This is usually in the for of ont of the feed wires being of higher resistance than standard wire.
It is such a strange problem it is difficult to diagnose without driving the car.
I have many questions about parts of the engine, ie what is what, but without the book, cant tell.
There is something else I have noticed which doesnt seem right, the HT lead from the centre of the cap goes about 10 inches back to an electronic device on the bulkhead. This has a couple of thin wires(1 blue, 1 black) which go about 2 inches left to a small square plastic block. This has an electrical connector similar to lots of others under the bonnet. What seems wrong here is that this plastic block gets extremely hot, too hot to touch for more than a micro second!! Do you think this is as it should be?
I would check the dizzy cap and rotor arm, replace if they look at all questionable.
Have you fitted new plugs recently?
