Looking for some pointers
Old Oct 17, 2003 | 06:46 PM
marcogyver's Avatar
Default Looking for some pointers
Plan on changing ATF along with filter tomorrow and the Bently made the job look pretty straight forward (95 A6 Auto/FWD). I am looking for any pointers that the bently doesn't tell you such as tools needed that I don't have or snags I may experience.
A couple of questions I have:
1. What has everyone used to measure the temp of the fluid?
2. Can you run the tranny with ATF but without the filler plug to measure the temp or do you need to check temp, replace plug, remove plug and remeasure?
Old Oct 17, 2003 | 08:48 PM
A6Gary's Avatar
Default Bentley manual states to perform level check @ idle, in "P", fluid @ 35 - 40 C, A/C off. Fluid...
temp is normally measured via VAG-1551/1552 or VAG-COM. But you probably could also use a Fluke meter and thermocuple (or similar temp measuring device) to determine fluid temp.
Old Oct 18, 2003 | 07:06 AM
marcogyver's Avatar
Can a thermometer be used to measure the temp of fluid in the pan?
Old Oct 18, 2003 | 03:36 PM
A6Gary's Avatar
Default Probably. You should be able to also measure the fluid temp by measuring the pan surface temp - ...
they should be essentially the same.
Old Oct 19, 2003 | 05:16 AM
ShoppingKartRacer's Avatar
Junior Member
what ATF fluid are you putting in?
Old Oct 19, 2003 | 05:55 AM
marcogyver's Avatar
Pentonsin ATF1 which is a direct replacement of the Bentley (G052162).....I hope!
Old Oct 19, 2003 | 06:02 AM
marcogyver's Avatar
Default Thanks for the info...I didn't get a chance for the change yesterday, hopefully today. I got the
important leaking final drive seal done friday. The smell of the gear oil itself is awful, nether the less the smell of it on a hot exhaust....whoooo.
kmrod
Mar 2, 2017 09:43 PM
m1964
Q5/SQ5 MKI (8R) Discussion
Oct 29, 2016 04:30 PM
Roach
Apr 23, 2007 03:02 PM
crakerhead
Audi 100 / A6 (C4 Platform)
Nov 8, 2002 09:42 AM
Tissa
Jun 7, 2002 07:20 AM
