O2 sensor replacement HOW ?
Old Oct 20, 2009 | 08:54 AM
lgranch1's Avatar
Default O2 sensor replacement HOW ?
Ok, I did do a search and came up empty for teh C4 platform and the 2.8 V6. With the heads off the job of replacing the O2 sensors is easy. So how is it done without taking the engine apart? Am I missing that there is a special tool other than a standard O2 sensor tool. I know it is 22mm. Give me a clue someone out here has done it.
Old Oct 20, 2009 | 10:13 AM
zeet's Avatar
The O2 sensors are not on the engine - they are on the exhaust. You don't need to touch the heads to replace the O2 sensors, they just unscrew from the exhaust pipe right before the catalysts.
Old Oct 20, 2009 | 10:25 AM
Just Me's Avatar
Tech Guru
Tech Guru
yea, i'm baffled too. On my 1995 2.8 C4, the 02 sensor is staring at me on the end of the manifold, out in the open screaming "turn me". Unliek the one's i've needed to replace which were buried between something burning hot and the jaws of a tiger.
It may be, ah, tight.
G
Old Oct 28, 2009 | 06:20 PM
a6hcw's Avatar
On the left side of the 2.8L 12 valve AFC engine there is a coolant pipe near the oxygen sensor, so you may have to modify an offset oxygen sensor wrench to clear this pipe. This may be done with a die grinder or a ginding wheel.
Old Nov 5, 2009 | 02:54 AM
Bigold 6's Avatar
This link will help.
http://www.12v.org/maintenance/repairs/o2sens.php
TXcajunman
Jan 12, 2015 02:43 PM
younggunfordfan
Dec 5, 2010 08:44 AM
DocWyte
Rocky Mountain Discussion
Mar 9, 2005 09:16 PM
odelay12v
Jul 5, 2004 09:20 PM
BVRN_RKT_94_90
Apr 20, 2004 07:41 PM
