Problem with Dash (OK)
Old Jan 16, 2003 | 01:50 PM
RDTVRS's Avatar
New Member
Default Problem with Dash (OK)
94 100s, They center of the the instrument cluster, that says (OK) when you start the car is all blured and fuzzy same when stereo is turned on, sometimes you can make out part of ok then others its completly blured out, any ideas??
Old Jan 16, 2003 | 02:12 PM
Muhammad's Avatar
It's probably kaput.
Old Jan 16, 2003 | 05:17 PM
marcogyver's Avatar
Default Re: Problem with Dash (OK)
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/17609.phtml">https://forums.audiworld.com/a6100/msgs/17609.phtml</a</li></ul>
Old Jan 17, 2003 | 05:17 AM
thoraudi's Avatar
New Member
I have had the same problem. My experience is that you should try to check all connections under your hood that links information to the FIS. Disconnect the connectors and clean with solvent, then reconnect. Especially the one close to the brake fluid reservoir. I have done that and problems with my display have been gone ever since.
QuattroJay
Feb 3, 2009 12:36 PM
2001S4ICS
Nov 11, 2006 05:21 AM
Kevin@ECM
Jun 13, 2004 07:55 AM
