Replacing struts...
A question though, is it ok to just replace the fronts? Because the back struts are still good, but the fronts are worn bad. Also, anything else I should look for? I understand the struts will give the car a firmer ride, but I don't mind. Are the OEM struts cheaper?
So replacing just the fronts with good shocks will give you 4 "good" shocks, making the ride at least more balanced than it is now. If you are pretty sure that the the rears are still good, I say wait. Your car has over 200K on it, and something big might go before the rear shocks ever do. I replaced my very bad front shocks at 100K, but still have the original rears. We're not setting up cars that need race-car balance here.
