Is this the same thing as the throttle position sensor?
Old Jan 9, 2005 | 10:40 AM
djdc's Avatar
Default Is this the same thing as the throttle position sensor?
If not, where could i get one?<ul><li><a href="http://www2.autopartsauthority.com/parts/autopartsauthority/wizard.jsp?year=1992&amp;make=AU&amp;model=100--002&amp;category=C&amp;&amp;part=Throttle+Switch"> TPS</a></li></ul>
Old Jan 9, 2005 | 11:19 AM
snowman '92 100's Avatar
Default I think so, but it would be cheaper to get a whole new Throttle Body with a good TPS on it.
and it would be less of a headache to change--4 bolts as opposed to a couple bolts, some springs, and some other garbage.. IIRC.
Old Jan 9, 2005 | 12:22 PM
djdc's Avatar
Ya, i was thinking about just doin that. Thanks
Old Jan 9, 2005 | 02:16 PM
audijim113's Avatar
Default i've got one.
i read your post and went to look in my stuff. there is a throttle body there. the switch is not on it, but it's around here somewhere. gotta look at my 92 100 and see what it looks like first. send me an email. i can let you have either switch alone or together with tb for a much less than $144.
jim
Old Jan 9, 2005 | 03:09 PM
djdc's Avatar
Default Re: i've got one.
Thanks. I think i might need to get one, i like to shop around before it actually goes out. so if i need it i'll probably be contacting you next weekend. Thanks
Loudgoldwing
Aug 6, 2010 05:58 AM
patrick10
Jun 5, 2006 02:00 PM
onfir3
Apr 22, 2006 06:08 AM
mpwolf
14
Jul 16, 2003 08:17 AM
YumyJager
Oct 20, 2002 05:04 PM
