Solution to the fast blinker problem.
Old Mar 9, 2002 | 06:59 PM
KaMaKaZieP -ALUMIN8-'s Avatar
Default Solution to the fast blinker problem.
After installing the leds into my turn signals i had the fast blinker because the resistance was different. Well i went to the local parts store and i got a variable load thermal blinker relay for a vw cabrio and bam! fixed the whole thing. the blinker relay is located right behind the dash, in out less then 5 minutes.
Old Mar 10, 2002 | 06:03 AM
SquallLine79's Avatar
New Member
Default Good deal! I posted below about some of the issues to think about with this but
it looks like you have it solved! And to think, if I had just read this first, I wouldn't have gone off on my usual long-post analysis...
-John
Old Mar 10, 2002 | 07:39 PM
Hah, i just read your other post. thats funny! mabye i could add a HYPER BLUE BLINKER TOO!
Old Mar 11, 2002 | 06:11 AM
QCRAZY's Avatar
That makes two of us!!!
Old Mar 11, 2002 | 06:14 AM
QCRAZY's Avatar
So how exactly does that relay work...Do you know?? Just curious!!
Old Mar 11, 2002 | 08:35 AM
ARK's Avatar
ARK
Default The stock relay has a current sensor circuit which senses the load current of the bulbs. Too low a..
current (like a burned out bulb) and the flash rate is increased to warn the driver. The old-fashoned thermoblinker flasher relays do not change the blink rate idf the load current changes.
Old Mar 11, 2002 | 08:37 AM
ARK's Avatar
ARK
Or, connect a 12 ohm 20 watt resistor across the LED blinker lamp terminals.
Old Mar 11, 2002 | 09:33 AM
QCRAZY's Avatar
Thanks ARK!!
Old Mar 11, 2002 | 09:39 AM
QCRAZY's Avatar
Default Hey ARK, since you list a 12ohm resistor......
...you must know the minimum current to set off the OEM relay.
Using your resistor I calculate it to be somewhere around 1A.
Is it correct to assume that is the miniumum current for the OEM relay (before it starts flashing faster??)??
TIA!!
Old Mar 12, 2002 | 08:28 AM
ARK's Avatar
ARK
Default I am guessing (with margin) that 1 amp of load current is enough to inhibit the fast blink rate.....
The actual threshold is probably less.
