transmission code
Old Mar 2, 2004 | 08:51 PM
seattle 93q avant's Avatar
New Member
Default transmission code
I have to replace transmission on my 93 audi 100 quattro.does somebody nows where I can find transmission code,my mechanic told me has to be 3 leters. This is automatic transmission,my overdrive is broken.
Old Mar 2, 2004 | 10:07 PM
manuva's Avatar
Side wall of the spare wheel housing.
Old Mar 2, 2004 | 10:48 PM
A6Gary's Avatar
Default Per Bentley Manual, the code letters should be "CEZ" for quattro auto trans. The code letters are..
located on the data plate below the right transmission support. If you have a manual, the code letters should be "CAD".
Old Mar 3, 2004 | 04:07 AM
Edd W's Avatar
Default The code is stamped on a small area that is machined flat on the top edge of the bell housing....
You must find the correct transmission to replace it because it is ESSENTIAL that you get the same ratio diff as is fitted in the rear.
I would only take the actual code off the box itself. Use the chassis ID plate as confirmation.
700kid
Oct 28, 2011 03:35 PM
SMOKIESMAN
Audi 100 / A6 (C4 Platform)
Sep 24, 2004 07:27 AM
j99t99
12
Jul 30, 2002 12:31 PM
jcblack
Apr 12, 2001 03:30 PM
