What is the setting on the magic decoder ring to remove the spare from....
Old Jan 28, 2007 | 05:52 AM
UrS4boy's Avatar
Tech Guru
Default What is the setting on the magic decoder ring to remove the spare from....
underneath the rear seat in Avant? I obviously am doing something wrong because as far as I have tried, the spare hits the bottom of the third seat and/or gets hung up on the black "volcano" that the spare is mounted to. I know if I remove the seat bottom I can get it out but that doesn't seem to be a user friendly solution, i.e. a wife having to use a 24 mm socket to get at the spare on the side of the road.
TIA (I did search the archives but didn't find what I was looking for)
Old Jan 28, 2007 | 10:03 AM
SoCal  Avanti's Avatar
Default That's the only way to do it.
The only way to get the spare tire out is to remove the 3rd seat. The bolt holding the seat is removed with the lug wrench. It's a bad design, but that's the way it is. Why you would need a 24mm socket is a mystery though. I think you're looking at the wrong bolt.
Old Jan 28, 2007 | 10:46 AM
UrS4boy's Avatar
Tech Guru
Default Wow. Bad Injinerin' from Team Doorhandle. D-U-M-B. (Thanks for the info I thought....
I was doing something wrong. At least now I know.
Old Jan 28, 2007 | 02:26 PM
UrS4boy's Avatar
Tech Guru
Default I take back some of the above. There is a knurled wheel attached to the bolt to allow removal by ...
hand, once it is started with the lug wrench.
Well, at least in theory. In practise, I had to use a 19 mm wrench to hold the captive nut from turning in order to loosen the knurled bolt. Then it moved by hand.
Old Jan 29, 2007 | 05:29 AM
Squirt-Tortuga's Avatar
Junior Member
Default You're kidding.... I never have a problem pulling out the spare on my '92 100q avant.
And I have used it before, on the side of the road...
Old Jan 29, 2007 | 06:53 AM
UrS4boy's Avatar
Tech Guru
You have the third seat?
Old Jan 29, 2007 | 07:01 AM
Junior Member
Default Yes. All I did was flip the seat up, then pull out the spare cover panel and foam"spacer".
Then the spare just slides out, between the seat bottom and the back of the compartment.
Old Jan 29, 2007 | 10:19 AM
UrS4boy's Avatar
Tech Guru
Does your spare mount to a black plastic "volcano"?
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 29, 2007 | 04:00 PM
Junior Member
It sure does...I might have to take pics to prove this!
Old Jan 29, 2007 | 04:16 PM
- GT Style -'s Avatar
Lane Shark
Upload a vid of yourself taking out the tire
HaroldB
Wheels & Tires Discussion
Dec 10, 2017 10:27 AM
UrS4boy
Audi Original "S" Cars
Jan 28, 2007 03:59 PM
Snopyro
Mar 26, 2004 05:21 PM
duglmac
Audi 100 / A6 (C4 Platform)
Oct 22, 2003 07:36 PM
Jeep2S4
13
Apr 18, 2002 11:27 AM
