Will not start
Did they remove the timing belt to replace the waterpump? Did they use the special cam locking tool? Could be that the timing is off.
See the following link for Ross Tech<ul><li><a href="http://www.ross-tech.com/index.html">Ross Tech</a></li></ul>
assuming it ran after the work was done and it ran ok, did you do anything since? i'm a firm believer in "what did i do last?" being the biggest cause of problems.
I had to start it for the tow truck driver it ran no problem.
tear it all apart and check the timing??
help
thanks
HTH and Good Luck<ul><li><a href="https://forums.audiworld.com/a6100/msgs/30838.phtml">No Spark</a></li></ul>
drove it home :-)
A BIG thanks to you all for your help.
