Oxygen sensor splicing question...
I have a generic 3 wire version that I will need to splice to replace mine...BUT...I'm a wiring moron. Anyone know of any write-ups or have any advice/how-to's for doing this process?
Thanks guys!
--morgan
The other two wires should be bundled in a standard 2 pole AMP Bosch connector. That is the heater wires. One is +12V (high current) the other is a ground. The heater pulls several amps so you want to run that with a relay triggered by ACC power.
Now for the real tip. If you bought the generic Bosch, it comes with connectors and thermal shrink insulating wrap. Strip the wire back about 3/8 inch. Slide the insulating wrap down one of the wires. Connect the two wire ends via the connector - DON'T CRIMP YET - now slide the insulation over the connectors and crimp. Use a heat gun to seal up. If you can pull of the entire O2 wire and connector ends its easy. (or you can be like me and do the crimping while under the car - duh...)
