Radiator Fan...WTF???
Old Nov 1, 2011 | 05:59 PM
8valvegrowl's Avatar
Default Radiator Fan...WTF???
So, I just finished repairing all the front end damage to my '87 4kQ. Topped up the coolant and fired 'er up. Everything runs just peachy, except the radiator fan doesn't kick in.
Tested the radiator thermo switch. It goes to zero resistance at the proper temperature range and is open when cool.
When I short the thermoswitch wires, I can hear the relay clicking closed and I measure 14V at the fan connector on my DMM.
I plugged the fan into a 13V power supply and it spins up fine. Plug the connector back in and the fan doesn't run.
What the hell?
I removed the A/C stuff while I had the front end apart (winter beater). But I can't see anything in the Bentley wiring diagrams that would indicate that I could eff something up by doing that.
Old Nov 1, 2011 | 06:15 PM
CJ Miller's Avatar
If you have power, how about ground? Check continuity for the fan ground connection. 2.5 brown wire in harness; on the later cars with the bigger fans that wire is fused to keep you from burning up the wiring harness if the fan draws too much current. Not a bad idea...
Old Nov 2, 2011 | 04:43 AM
Yeah, I was going to start tracking down grounds next...although if I measured 14V across the fan connector when the relay is closed, you'd think the ground would be sufficient. Who knows. Electrical gremlins are always fun...
Old Nov 2, 2011 | 01:19 PM
Rogviler's Avatar
If you unplug the wires from the switch at the bottom of the radiator and jump them together, are you saying the fan doesn't come on when you turn the key on but the relay clicks? It should definitely come on in that situation. If not then I would suspect either a bad relay (cracked solder joints) or a bad wire.
-Rog
Old Nov 3, 2011 | 07:08 AM
Yep, with the car idling, I can short the thermoswitch wires and hear the relay click. When the relay clicks over, I can measure 14V across the fan connector. If I plug the fan connector back into the fan, it doesn't run. If I use an external power supply to supply 14V to the fan, it spins just fine.
It's got to be a wiring/grounding issue...my favorite!
Old Nov 8, 2011 | 10:20 AM
Problem solved!
The white connector on the back of the fan wasn't seated fully, I ended up having to use zipties on the connector to apply enough pressure to keep it working.
Old Nov 11, 2011 | 05:36 PM
CJ Miller's Avatar
Default fan connector
Originally Posted by 8valvegrowl
Problem solved!
Careful here; if the fan connector (on the fan) is failing, it can sometime be due to a failing motor, drawing a larger than normal amount of current, and starting to melt the connector. If that is the case, next thing to melt is the wiring all the way to the fuse panel. I'd add a fuse to the ground side of the harness.
Another thing that can cause the connector to fail is the amount of tension on the harness; seems that Audi didn't want to spring for another inch of wiring, so sometimes there is constant tension on the connector.
Old Nov 13, 2011 | 10:57 AM
audi-driver1126's Avatar
Hey guys, my 4000's temperature guage doesnt work anymore, just sits at the very bottom, even after a long drive. What is going on here? just a sensor?
Old Nov 14, 2011 | 04:16 AM
Thanks for the tip re: the connector. Mine is purely a mechanical problem. In the accident, the radiator got pushed back slight and the plastic tabs that hold the connector into the metal housing of the fan motor were damaged. I didn't see any evidence of arcing or melting back there.
That wiring harness is a pretty tight fit, not a lot of strain relief there.
colorado coupe
Jun 4, 2016 06:05 PM
gateway
Dec 29, 2011 07:48 PM
Audibama
Audi 100 / A6 (C4 Platform)
Jan 25, 2007 02:47 PM
Jon-1.8t
Jan 21, 2007 09:05 AM
jkpriyan
Apr 30, 2006 07:53 AM
