2113 hall sensor code.
Old Mar 12, 2006 | 08:08 AM
yawdi's Avatar
New Member
Default 2113 hall sensor code.
managed to finally get a code relating to my hot-start problem, only it happened when parked in a loading zone. Any ideas on how to bypass the no-spark temporarily before i get towed?
Old Mar 12, 2006 | 01:30 PM
audiqv8's Avatar
Default Re: 2113 hall sensor code.
1st off you shouldn't be parked in a loading zone unless you're there to pick something up. Try a little starting fluid if the problem is caused by the check valve.
Old Mar 13, 2006 | 03:39 AM
boxerfan's Avatar
Default Since you are an Ottawa fan...
The Hall sensor is a dual sensor and relates to either the level of the Halogen Fluid in your headlights or the need to replace the air in you rear tires. LOL... I crack me up...
Actually, you're pooched. This is a code that indicates the Hall sender on the distributor is either out of alignment or, and most likely, no longer functioning. Get it started and het it home. Then go haunt your local scrapyard in search of one.
Old Mar 13, 2006 | 08:25 AM
5000CDQturbo's Avatar
got your message yesterday that you had phoned a couple of days ago ... oops I've been skiing lots ... I'll give ya a call tonight. or call me at work 784.3231 dave
Old Mar 13, 2006 | 05:49 PM
yawdi's Avatar
New Member
Default Re: Since toronto wont make the playoffs...
couldnt find halogen fluid in walmart's extensive automotive department, so substituted 94 octane. might get better lighting! j/k
Called CAA (membership is worth every penny), got it towed. at least it was good weather.
chrisbob
28
Feb 23, 2013 05:48 AM
toothandnail
Oct 21, 2010 05:53 AM
Biscuit141
Audi 100 / A6 (C4 Platform)
Apr 14, 2004 10:13 PM
Bruce M
Sep 21, 2003 05:42 PM
iNfiNkC
VAG-COM Discussion
Apr 2, 2003 12:44 PM
