bad ground? or bad switch?
Light turns red, I step on the brake and hit the left turn signal. Whoa it suddenly gets brighter and I suddenly wake up from my foggy haze... WTF?
both turn signals are lit although the left one is blinking because I hit the turn signal. My high beams are on but the blue highbeam light is only dimly lit. Speedo's mph lighting is dim up to 40mph. I complete my turn and turn the lights on and off and the high beams turn off, but the turn signals are still both on and the dim mph is still there. Looks like the blue highbeam dimly flickers with the turn signal. Turn off car to pick up my son and when I go to start it again, all I have are highbeams.
Flip the light switch 1 notch to parking light mode and all the brights turn on. Engaging high beams does nothing. drive for about 5 minutes and try the on-off flip of the switch and finally the high beams turn off.
so has anyone experienced this before? I'm going to start my suspicion with the turn signal switch since this all started as soon as I hit it.
On my '91 200q; when the car was started the "OK" symbol would occasionally come up as a series of lines. It also happened when the cooling fan circuit lost the fused ground and the car overheated; I couldn't tell what was alarming, only that it was red. Sometimes a firm slap on the dash over the display would fix it, or shutting the car off and on again.
When I developed further problems (putting on the high beams illuminated the turn signal indicators, the turn signals flashed the high beam indicator and the opposite signal indicator, the dash lights started going off & on, etc.) I suspected a ground fault & pulled the instrument panel.
Sure enough, there was an intermittent ground on the board. There are two ground clips which look like computer board jumper blocks. The pins which engage in these allow the circuit board and the main instrument cluster to be seperated. The spring contacts inside the jumper blocks had relaxed and were making an intermittent ground. I built up the pin diameter with solder and voila! - problem solved. I haven't had the problem with the warning display since - here's hoping!
HTH Fred Munro '91 200q 245k km<ul><li><a href="http://members.aol.com/c1j1miller/index.html">http://members.aol.com/c1j1miller/index.html</a</li></ul>
There's some information on IC removal and repair on Scott Mockry's <a href="http://www.sjmautotechnik.com/trouble_shooting/instrument.html#IC">WEBSITE</a>.
If I flick the light stalk while I pull it slightly toward the steering wheel the normal city lights turn on but as soon as I hit high beams they stick on until I turn off the lights and gently pull on the light stalk while turning it on.
I still say it's the light switch since the initial problem introduced itself when I flicked a left turn.
Time to pull out the bentley.
I fixed the trunk hinge and driver's door hinge wiring at the same time as well.
All the 5k cars I bought up were to strip parts from.
