brakes hesitate and stutter till anti-lock warning light comes on
Ive checked and all four of the calipers are working correctly. I also made sure the lines were bled correctly and that there werent any pinches in any of the lines.
The bomb hasnt worked since I got this car 6 years ago, so I wouldnt think its that, and the steering isnt affected, so I wouldnt think its the brake/ power steering pump. Could it possibly be the abs pump? And how would I go about testing the pumps?
Any thoughts or problem experience would be a great help! Thanks!
A good thread regarding ABS sensor troubleshooting: http://www.honestjohn.co.uk/forum/po...ex.htm?t=16782
A second point: I'm sure that the original poster's Audi 200 has 4 -- not 2 -- sensors: one sensor on each of the four wheels.
I usually measure the outputs of all four from one place: beneath the rear seat. Remove the large ABS computer plug and all four sensor outputs appear on it. (Unfortunately for the OP, I don't have a schematic for the 200.)
Also, square waves could work. Its not the proper way to do it, and you can miss information, but if you know how to read it, it works. Sine are much easier to figure out exactly what is causing it though.
What I was hoping to get the diagram for was basically which color goes to which wheel. Ive tested them and actually have 2 that are not reading correctly (Im hoping Im correct on this one). One isnt reading at all, and one is showing some minor disruptions that cleaning may take care of. I just dont know which those are, and dont want to pull out the two reading well and clean them if I dont have to. I did have the front wheel bearings replaced on both sides a couple months ago and am curious if those are the 2 malfuntioning.
p.s. I dont have a lift and was too lazy to jack up all four wheels on stands; so I set up my oscilloscope in the passenger seat with lead extensions from the harness to watch while I drove at a constant speed down the highway. I know it wasnt safe but thought the mental picture would give those EE/ME nerds out there a laugh!
I have no idea what you mean in your second paragraph.
I was referencing *Number68*'s statement about how to check function of the sensors on the oscilloscope using "square waves". (I understand that the sensors work like a generator, using the magnetic passing pulses from the teeth on the CV gears to create an alternating current in the wire between the sensor and the computer. The computer then analyzes the input and compares it to an ideal model.) It will still show whether it is functioning or not, but not much more than checking resistance with a VOM will. It wont be able to show the actual output of the sensor, just whether its outputting or not. It's all in the way to set up the scope when checking signal.
