fun with idle problems......(longish)
Thanks
Jeff
With the throttle plate closed (foot off the gas) the throttle switch directs the ISV controller (marked as Idle Volume Control on my fuse panel, gotta love the translation) to regulate air flow into the intake manifold using the ISV. The ISV contains an air regulator disk controlled by a solenoid. With current applied to the solenoid the disk will move toward the electrical connector providing a path for air to enter the intake manifold. With no power applied a return spring returns the disk to the shut position.
It was suggested that a vacuum leak could cause the problem. It was not clear to me how a leak could cause the engine rpm to increase. It seemed that the increase in rpm was likely due to an increase in metered air and the engine computer was responding accordingly. I felt a vacuum leak would cause unmetered air to enter the intake manifold resulting in an idle stumble.
As suggested I cleaned the ISV and then tested it with a 12 volt/half amp power supply. The disk moved freely and snapped shut when power was removed. One notable difference was that the replacement ISV would not pass air when I blew into the inlet side of the ISV. The problem ISV would allow air to pass.
I replaced the ISV with a used one from Force 5.
The throttle switch will make a clicking noise when the plate closes. It's a good sign if it clicks but not enough in itself. You can measure for continuity by removing the connector.
I don't know what the extra connector is for.
