Megasquirt EFi on my 10v turbo, what do I need?
What do I need to make this come alive? A detailed list of parts and installation guide/tips would help out greatly.
You Will need,
(1) A fuel rail
(2) Injectors (since you want more power, I believe the 42lb injectors are probably the smallest you'd wanna go
(3) Injector Inserts so you can get the injectors mounted properly in the head
(4) A Fuel Pressuer Regulator of some kind
(5) Fuel Lines and fittings to mate with your existing source
(6) For my 034 setup relays were needed, I don't know about Megasquirt
(7) After dealing with a tuning nightmare, I HIGHLY recommend a wideband 02 sensor, but you CAN tune without one.
(8) Assuming this is on a 10vt motor, you'll need the 5-window distributor from a NA 5 cyl motor.
...Its important, in my mind, that whatever you work the price out to exactly, add a couple hundred dollars more for small, stupid stuff that might (and usually does, in mu case) pop up.
There's more... but I've got class now. Adam and Jeff are both on here, both have megasquirt (I think) and are real helpful.
Looks like I can source these parts over the winter this year.
anyone
fuel injectors from racetronix.com
fuel line and fittings from jegs.com
fuel pressure regulator from autozone or ebay
diyautotune has the IAT sensor
I'm using stock coolant sensor
that should get you started
