1990 Audi 80 running problems
When you start it up, it chugs and runs rough, UNLESS you feather the throttle JUST right then it will smooth out.
When its driving, its incredibly nonresponsive. If you put the gas to the floor it hardly crawls, and slowly builds rpms then stalls out at about like 4000ish? It acts similar to being starved of fuel buuut the plugs dont look leaned out.
My thoughts,
Vacuum leak
Control pressure too high
Clogged injectors
I dont know much about the K-Jetronic system at all, nor how these audis are really set up, ive been a mitsubishi guy for a long time.
Any and all help will be GREATLY appreciated.
Also, does anyone know where to get a repair manual for this that isnt like 120 bucks?
And, the fuel pump doesnt seem any louder than any other car Ive ever owned so I will assume its ok. But Ill try the seafoam thing, and then also replace the fuel filter when I get some money to throw at it. I know they arent that much, im just tight budgeted right now.
Also, after posting this I did find a couple vac hoses that were old and showing sings of cracking, soooo new question, just how detremental is a vacuum leak on the k-jetronic. In my mind it would be pretty bad considering the way these meter the air, and how the air meter runs the fuel delivery.
So I was thinking of unhooking the vac hoses from the intake plenum and capping them and trying to run it. See if it gets any more responsive. Any thoughts on that?
if i understand correctly, the voltage it puts out at op temp should be 0.8-1 volt, but the pdf also explains what everthing else does and how it does it, so might be some good reading material if your interested, or thinking about it, its prolly 0.8-1 ohms of resistance (shrug)
Next step will be to replace that one vacuum line, its like a 1/2" line, pretty big leak there.
After that try to run it again, maybe with a can of seafoam in it, and see if it gets any better. If not. Then on to the engine codes and scoping out that O2 sensor.
Btw, I really appreciate the responses Ive been getting thanks guys.
