4X108 Wheel Spacer Question
If one was able to move the entire suspension, inner mounting points and all, outboard; then the wheel bearing would not see a change in load.
I have two other concerns, one is drive-ability, the other more a body-work maintenance thing that may be affected by such a track change:
a.) steering geometry change; &
b.) fender damage.
Our cars have what is termed negative scrub radius steering geometry. This is dependent on the relationship between a theoretical point on the ground inline with a given wheel/tire's steering axis, and the centre of that wheel/tire's contact patch. This feature makes these cars more inherently stable in conditions of unequal traction and in cross-winds. As you move away from OEM design conditions, you degrade this feature.
Our wheels constantly spit off gravel which is largely contained within the plastic wheel-housings. As you move the wheels outboard, you will see more eventual damage to the paint-work. For instance, the extreme lower edge of the fender lip, and the rear fender arch in front of the rear wheel picks up a lot of damage.
Whether the above is of any concern at the distance you mention, others who have done this may be able to say.
