95 audi 90 quattro tranny problem
Old Feb 25, 2011 | 12:46 PM
tonyrhs13's Avatar
Default 95 audi 90 quattro tranny problem
well on my way home from work today my tranny popped out of 2nd gear while driving so i tried to stop and get into first no good lost first. still had 3rd 4th 5th and reverse. tried to make it home with 3rd then lost 3rd! so i had to drive 2 1/2 miles back to my shop in REVERSE still got reverse tho. needless to say i need a new transmission.unless some one thinks it could be something stupid but doubt it haha .its been making an awful noise for a few months now.
what i need to no i 2 things
1. there is 2 different manual trannys 'cbr' and 'cvx' need to no where to find out which.
2. how much of a pain is it to change the trans in this beast.
thank, Tony
Old Feb 25, 2011 | 01:40 PM
varia's Avatar
did you check the clutch?
your car had a 01A trany if im not mistaking:
B4 90quattro 1993-94 tranny case 01A- torsen center differential
1st-3.500
2nd-1.842
3rd- 1.226
4th-.943
5th- .816
final-3.89:1
Old Feb 25, 2011 | 02:06 PM
tonyrhs13's Avatar
i dont think its the clutch because it goes into all the gears fine.
when i let the clutch up it grinds and pops out of gear even if i hold it there.
on this website car-part.com it gives you 2 choices cbr and cvx code transmissions. not sure if it even matters but theres a huge price difference.
Old Feb 25, 2011 | 02:44 PM
maineman's Avatar
Default trunk
In the trunk under the mat where the spare tire is there should be a sticker with codes on it .One of them will be your tranny code.Also paint code there.
good luck
Old Feb 25, 2011 | 03:03 PM
varia's Avatar
Manual transmission 01A
Transmission code letters CBR
Manufactured from: 10.91 to: -
Application Model Audi 90 quattro
Engine 2.8 liter V6 128 kW (172 hp)
Ratios Final drive
35 : 9 = 3.889 :1
(Z2 : Z1 = i)
1st gear
35 : 10 = 3.500 :1
35 : 19 = 1.842 :1
38 : 31 = 1.226 :1
33 : 35 = 0.943 :1
31 : 38 = 0.816 :1
31 : 9 = 3.444 :1
Speedometer drive Electronic
("ETKA the CVX is unique to '95 90 quattros. The CBR/CPN was on '93/'94/early '95 90 quattros and '90-'91 coupe quattros")
Lubricant Capacity 2.85 liter (3.01 qt.)
Specification SAE 75 W 90
Gear oil (synthetic) Part number: G 005 000 (1 liter)
Clutch control Hydraulic
Clutch disc diameter 240 mm (9.45 in.)
Drive flange diameter 100 mm (3.94 in.)
Overall ratio in top gear 3.173 : 1
Old Feb 25, 2011 | 03:43 PM
tonyrhs13's Avatar
i forget the month it was manufacterd but would it matter which one i get.
whats the differences.
and another question what kind of gear oil do i use and what weight does it have to be audi sythetic.
Thanks for all the help good information.
Old Feb 25, 2011 | 04:55 PM
varia's Avatar
Idk whats the different between those but i will ask a trany guru.
gear oil:
Gear oil (synthetic) Part number: G 005 000 (1 liter) (i just posted in my last post)
2001s4loored
17
Sep 11, 2006 11:30 AM
shapiror06
Jun 20, 2006 09:40 AM
cscoles
14
May 14, 2004 08:26 AM
Firemeddtech
Misc. Models Discussion
Apr 15, 2001 04:36 AM
Marty H
Feb 19, 2000 04:09 AM
