ABS problem
Old Jan 7, 2003 | 12:53 PM
Kevin Coholan's Avatar
New Member
Default ABS problem
It is a 1988 90 Quattro, 2.2 (KV). The abs off warning light is on the whole time and the switch will not put it back on. I checked the relays on the abs unit and they seam ok. Would a dirty of out of place sensor cause this? Or would it just mean that there would be no abs at that individual wheel?
Old Jan 7, 2003 | 01:05 PM
mroberts's Avatar
Junior Member
Default Cleaning sensors is usually the first step ...
If it's getting a funky signal from any of the sensors it will switch itself off.
Does it come on as soon as you switch the ignition on, or after driving a bit ?
Old Jan 7, 2003 | 01:48 PM
New Member
Default Re: Cleaning sensors is usually the first step ...
The light is always on, from when i turn on the key. Do I just take out the sensor and clean them with a cloth? How about the tip of them?
Old Jan 7, 2003 | 02:50 PM
Jim Bush's Avatar
Default Try the fuse under the dash on the ABS relay
10 Amp fuse the only one sticking out of any relay (similar to a fuel pump relay). Under the dash by the drivers left knee.
In a sensor problem the light will come on only after driving a short distance.
Jim Bush
Holland, MI
RallyAudi
Jun 26, 2011 07:46 PM
quattro_rocks
Audi Original "S" Cars
Mar 16, 2009 08:20 PM
SLAB
14
Nov 26, 2003 09:44 PM
green88'90Q
15
Apr 27, 2003 07:41 PM
mint875000cstq
Mar 28, 2003 05:46 AM
