Audi 90 Radiator Fan Relay Numbers.
Old Dec 8, 2003 | 09:11 AM
Marcin's Avatar
New Member
Default Audi 90 Radiator Fan Relay Numbers.
I just realized that when I bought my 95 Audi 90, the high-speed fan relays are misssing. Car drives fine, because at lower temps the fan kicks in. At higher temps I usually go fast.
Does anybody happen to know part numbers for the relays? I called a few dealers, but their answers are murky. The realays are located in the breaker box. The fan relays are top row. The second and the third relay counting from left. Maybe someone could look it quickly up.
BTW is there any good source for after-market relays? I looked everywhere and no one has cooling fan relays.
Thanks a lot for help.
Marcin.
Old Dec 8, 2003 | 10:46 AM
OCDaudi90q's Avatar
New Member
Default Wow a coincidence.
I also own a 95 Audi 90 quattro and Im missing the High speed rad. fan relay and the radiator fan delay.I believe you can just use a multi purpose 40amp one. but that im not quite sure of. I dont feel like paying 120 a piece for relays. I am gonna start looking for audis at jnk yards and grabbing the relays for them. Tho michigan doesnt have many junk yards with Audis in em.Maybe we can find some other 95 owners and see if they have relays or not.
Old Dec 8, 2003 | 11:26 AM
zeems's Avatar
Default Those are supposed to be empty...
...if you're both talking about the same one's I'm thinking of in the fuse panel in the engine compartment.
Old Dec 8, 2003 | 12:53 PM
spillmania's Avatar
New Member
Default Re: Those are supposed to be empty...
I've got a 93 and I've noticed the same thing.
Old Dec 8, 2003 | 01:17 PM
The Puke's Avatar
Junior Member
Default According to ETKA
As far as I can tell, ETKA shows that position 10 (3rd from left from your description if I understand it correctly) is a relay for daytime running lights, which our cars don't have. The part # given for the relay is <I>443.951.253.K</I>.
Old Dec 8, 2003 | 02:54 PM
Marcin's Avatar
New Member
My problem is, that the fans do not spin at high temperatures. One time on a hot summer day during 6000' climb in Yosemite I got the engine going about 3/4 allowable temp and the fans were not spinning when I stopped with the engine running. I thought they were broken, but when engine cooled down, the fans were working fine. That is what started me searching for the relays. Also, when I do get stuck in traffic, it takes no time to go almost half-way the temperature guage. I am always in safe zone, and the temperature goes down once I start going, but it is concerning.
The dealer did not have much clue about it. The guy was asking me for the relay number (the other relays are marked like I-204, Y-208), but it is hard to give him that when the relay is missing. He came up with some fan relay for $52.
I will have to look at wiring diagrams and figure out what the hell is going on.
Thanks guys for help.
Marcin.
Old Jul 15, 2013 | 11:29 AM
spharr's Avatar
Default cheap relays
partsgeek.com has good prices on relays i have the same problems my fans never engage i think its due to the missing relays also
Old Jul 15, 2013 | 03:58 PM
egp320i's Avatar
Banned
There should be a relay in #2 for the high speed fan. I just found out after all these years mine was missing as well.
This fan kicks on around the 3nd notch on the temp gauge after the heavy "normal" mark with the low speed at the 2nd mark.
If you are running AC the low speed always runs but if you get to the 2nd mark after the normal mark then high speed kicks on.
Course this also must mean your fan switch in your radiator is working properly too.
Old Part Number 8D0 951 253A
New Part Number 4H0951253A
#3 was omitted for the B4 and should be the only open socket.
<a href="http://tinypic.com?ref=23ifnsz" target="_blank"><img src="http://i42.tinypic.com/23ifnsz.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Jul 15, 2013 | 08:38 PM
varia's Avatar
it was a ten years old topic...
Old Jul 16, 2013 | 02:10 PM
egp320i's Avatar
Banned
Oops, forgot AW does not bump up new threads as well.
No big deal, maybe somebody will find it in a search someday and find it handy.
A newcomer bumped the thread.
Gee_Herbie
New Member Welcome Area
Sep 26, 2016 05:42 AM
quattrosissy
Inline-5 Discussion
Jun 8, 2006 07:10 PM
misanthrope
May 15, 2004 08:30 AM
V-C4
Mar 5, 2004 11:30 PM
poloa4
Jan 20, 2003 07:18 PM
