Audquad...
Old Jan 28, 2004 | 12:21 PM
Blake@NWAutoSalon's Avatar
Default Audquad...
How hard was it to attach your Certifit hood?
Old Jan 28, 2004 | 01:33 PM
Audilard's Avatar
Default Re: Audquad...
I bought a certifit B4 hood. Unbolt old hold, remove hood latch, windshield washer squirters and lines, and the hood pins.....attach hood latch, windshield washer squirters and lines, and hood pins....and bolt the new hood on!!
It really is that simple. You will have to adjust the pins so that the hood lines up with the fenders.
Old Jan 28, 2004 | 02:13 PM
Did you keep the original hood latch? How does that work out for you?
Old Jan 28, 2004 | 05:13 PM
Audilard's Avatar
Default Re: Did you keep the original hood latch? How does that work out for you?
Yes, I kept the original hood latch from the B3 hood. It bolts right in. When you close the hood it catches just like it normally does. When you pop the hood you have to find the latch with your fingers and push it over. I'm used to it now and can find it without looking, but when I get the car inspected or something they have no idea how to get it open....cracks me up....like its got a secret button or something. 8-)
Old Jan 28, 2004 | 05:14 PM
Audilard's Avatar
I also kept the B3 rad supports.
Old Jan 28, 2004 | 06:28 PM
Audquad's Avatar
New Member
Default Re: I also kept the B3 rad supports.
Sorry it took so long to respond but I see you have your answer! LOL
Old Jan 30, 2004 | 10:37 AM
8Rings's Avatar
Senior Member
Default It's easy to modify the B3 center for the B4 latch
I cut out the horizontal pin that the hood latches to, popriveted in a B4 "parrots beak" catch about half way up the center rad support "channel" and bolted in a dealership ($36.00) release that pokes out my Kamei grill just like a B4 should. Slick and easy!
lilmotor01
Feb 19, 2021 06:14 AM
4.2MingBlue
Apr 15, 2002 05:41 AM
Alain
Quattro: Turbo / Ur / Sport
Mar 10, 2002 11:11 AM
vrsix
Sep 15, 2000 08:16 PM
