gonna build a 2.6 liter 5 cyl turbo for my B4 - let the mad science begin! tech stuff inside (LONG)
Old Aug 5, 2002 | 01:07 AM
  #21
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Good Luck! :o) Bring Lots-O Cash! You'll need it!
For the time & money your about to invest, why not just get an S4?
Old Aug 5, 2002 | 04:56 AM
  #22
snoogins's Avatar
Default He's not talking about a "racing" O1E. O1E's came stock, in both 5 and 6 speed configuration, in...
...the later S2's, RS2's, C4/6 (ur-S4/6), and a few others.
Old Aug 5, 2002 | 05:44 AM
  #23
Don@STaSIS's Avatar
Former Vendor
Default Re: He's not talking about a "racing" O1E. O1E's came stock, in both 5 and 6 speed configuration, in
Howdy! Yes I was speaking of the stock 01E 6 speeds. Though I am intriqued to hear about these "racing" 01E's. Are they stuffed with VAG Motorsports internals? Strengthened diff? I'd love to know more.
Thanks!
Old Aug 5, 2002 | 09:07 AM
  #24
Hokie - STI avant's Avatar
Default Then it's just not a clever name....
~Wayne's World
Mike
Old Aug 5, 2002 | 12:50 PM
  #25
squidix9's Avatar
No Bozos!
Default Sorry..
When talking about extra HP, I assumed you were also, regarding the trannies. They do have different guts. #1 no center diff, it's locked at 50/50 f/r. Also they're limited slip, with a final of either 4.11 or 4.86 depending on vintage. Since they're under a lot higher stress, the gears are hardened. I don't know of any spare ones in the US right now, but they occasionally do surface. The last I saw went for $12K, as i mentioned before. Oh, and their noisy as hell too.
Old Aug 5, 2002 | 08:38 PM
  #26
cuatrokoop's Avatar
Default Re: gonna build a 2.6 liter 5 cyl turbo for my B4 - let the mad science begin! tech stuff inside (LO
you've NEVER looked at a straight 5 without the head on it have you... Ain't no WAY I'd bore it past 83mm (2nd factory oversize). There is NOT a lot of "meat" between the cylinders. Take a look at the bare block picture on my website of the 7A with the standard 82.5mm bore (my spare long block). "Same" block as an AAN/ABY just larger bore. Now tell me if you want to run lots of boost on cylinder walls that are even thinner than what the 7A has. I sure as hell wouldn't, unless I had several short blocks laying around. Granted, thats my opinion, but take measurements, and get out a calculator and figure out the wall thickness of an 83 or 83.5mm bore 5cyl. Not much left there for a high boost application. Audi goes with the 79-81mm bore on the turbo engines for a reason. Ever wonder why those engines last so long?
urwhat
Quattro: Turbo / Ur / Sport
18
Mar 7, 2006 05:26 AM
IGivMyAudiHed
Nov 24, 2003 02:29 PM
Senna4Life
Jan 6, 2003 08:30 PM
zspturbo
11
Nov 28, 2002 09:32 PM
a90quattro
19
Nov 20, 2001 04:39 PM
