help ! audi 90 2,8 - cam seals
cam seals are leaking need to replace, is there special tools to hold the cams in place when i remove the sprokets ?
please any help
1 ?, cams have NO key ways ? so when i pull off the cam sprokets- the cams can rotate - even a sm bit ? i dont see any cam shaft holding tools. how do i make sure cams are extally on the spot of allingment ?
i get it about , locking the crank in place, makeing sure all is at tdc.
but with out any key ways, how the heck do i know if cams have moved ?
it appears that the long bar holds sprokets, but when removed what holds the cams ?
i have the ebahn cd, not very clear. does haynes cover this eng in a diff book ? haynes does not make 1 for the 1995/90. of a diff repair book ?
i can strip & rebuild a e30 bmw ! but i clearly do not understand how to make sure cams are extally in time - or am i just missing something ?
thanks for the reply
scroll down until you get to the 12v v6 timing belt water pump procedure by catamount and click on it. Good procedure with pictures to help you along.
good luck
https://www.audiworld.com/forums/sho....php?t=2813378
i see the D shapes on the sprockets, with the crank holding tool & the bar , makes it set. (good thing ) for the D shapes !
a few other links tell how to do it with out the bar (& i understand ) but its worth the Audi tool rental for $40 to make sure.
my BMW's (e30's & e28's) use TDC , key wayed shafts & molded arrows in sprockets & Cly head to line up. gee Audi whats up ?
wasn't GM involved with auto union ? (lol)
THANK YOU VERY MUCH GUYS
+10 FOR AUDI WORLD MEMBERS !
might as well change water pump & T stat at the same time.
who has best deal on OEM (like) parts ?
pelicanparts i use for my BMW stuff - they have some Audi stuff - anyone better ?
AGAIN THANK YOU - THANK YOU - THANK YOU !
