Overheating
Old Jan 17, 2006 | 09:37 AM
imungrue's Avatar
Default Overheating
1996 Audi Cabriolet (115k miles)
Had a problem with the car overheating and using up coolant, replaced the overflow tank about 2 months ago.
Everything seemed Ok for a while, but then the car started overheating again, and had a new water pump put in.
Now just 1 week later the car is still overheating, and there is some smoke comming from the engine in front of the drivers side.
Does it sound like I have to get a new radiator, or might it be something smaller?
Need Help
Old Jan 17, 2006 | 09:38 AM
CvTech's Avatar
thermostat
Old Jan 17, 2006 | 09:40 AM
virtuapete's Avatar
Junior Member
Default the "smoke" is probably steam from the evaporating coolant...
coming off a leak somewhere or the thermostat. I would get the car running to the point it does this... park it, e-brake and lift hte hood and start hunting the steam down. you will most likely be able to smell the anti-freeze, but it should be fairly easy to locate with it running. scour the ENTIRE radiator's surface for moisture/condensation and then go over EVERY coolant hose and connection.
Old Jan 17, 2006 | 09:45 AM
imungrue's Avatar
Default Re: thermostat
Had the thermostat replaced also with the water pump/ timing belt.
Old Jan 17, 2006 | 11:57 AM
lemieux@curbside's Avatar
no white smoke coming out the exhaust ?
Old Jan 17, 2006 | 02:01 PM
imungrue's Avatar
Default Re: no white smoke coming out the exhaust ?
No , not that I can tell.
rigoberto_alcazar
30v V6 Discussion
Sep 10, 2017 06:41 PM
Avdwaal1
36
Feb 17, 2016 05:33 PM
tooofast
Jan 29, 2009 06:19 AM
silver go fast
Dec 4, 2004 12:07 PM
Dean_Audi
Aug 2, 2003 01:00 PM
