short to ground fuse 28
I was having the WOT/idle switch code flash on and off and sometimes stay on. The switch is fine, but I'm guessing the short must be in that harness. I'm getting all sorts of shorted wires to the ECU and ignition control mod. This must be because the + flow is going to ground somewhere. The car runs fine (idles high 1,100rpm) even with the shorted wires all plugged in.
So where do all the right engine wiring harness plugs go to?
I have swapped these parts to know:
ECU is good
Ignition switch is good
