stereo installation...
Any other ideas?
The Audi deck uses three plugs, two are for the speakers (front gets a plug, rear gets a plug, and your rears are AMPLIFIED so you WILL burn the amp up if you run them off the new deck!). The Power/GND/Ant switch group also gets its own plug.
Here are a couple pics of a Jetta GLi deck I have, and is what I used when I rewired my CQ's wiring to match the VW (and Blaupunkt) wiring scheme. You need to condence the large 10-pin plug (rear speakers) with the 4-wire, 8-pin plug (front speakers).
<img src="http://web.ics.purdue.edu/~fergusoe/DSC00004.JPG">
<img src="http://web.ics.purdue.edu/~fergusoe/DSC00005.JPG">
Orange or Yellow is the Face light Power (so it can be switched if desired)
There are sevral Speaker connex you'll have to figure those out (connect to a AA battery and you'll hear a scratchy sound from the speaker)
The blue wires, one for the power antenna, and one for the door buzzer (to remind you the radio is still on if you have non switched power to the face lights.
That's all I can remember for now but it should at least get your power on.
