Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Old Jul 29, 2016, 10:23 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A3 Interior Guides
Print Wikipost
2007 A3 Service Reset
Old May 15, 2008 | 06:45 AM
MrWilliams2002's Avatar
New Member
Default 2007 A3 Service Reset
Hi hope someone can help, have a 2007 A3 2.0TDi trying to reset service on the dash. Using VAG Com 704.1 all upto date, using the SRi function unable to reset mileage to next service, keeps coming up 1300miles left. The days change depending if we try long life or fixed BUT the mileage always says 1300 mile !!!!
Also tried the adaptation route, channel 2 to zero, this was on 2 which I`ve not seen before. All other as per ross-tech guides are right.
I guess Im missing something just cant see what :-)
Thanks for help.
Gary
Old Aug 11, 2008 | 07:37 AM
blackberry's Avatar
New Member
Default Re: 2007 A3 Service Reset
Old Jun 24, 2010 | 08:00 AM
PGAGoober's Avatar
I realize this response will be of no use to the OP given the time passed since the question was asked but I just now did a bunch of searching looking for the same info and couldn't find it. I too have a 2007 A3 and the instructions in the owner's manual for resetting the interval did not work.
So here is what I believe finally did the trick. (I say "I believe" because I tried so many different things I can't be 100% certain but I'm maybe 95% )
1. Start the engine (may not need to do this - perhaps just turn on the ignition ? )
2. Pull the reset **** to the right of the trip computer display. The display should now show you the miles/days to your next service, or in my case by how many miles you have exceed your service interval.
3. Release the reset **** and then pull on it again, holding it out until the interval resets. The display should now read something like service in --- miles/--- days.
4. Restart the car and the service warning should be gone. To double-check you can again pull briefly on the reset **** to show the remaining miles/days to service. It should be reset to 10000 miles/365 days assuming your service department correctly reset the interval at your 5k service. Mine did not and I had it done via vag-com.
I hope this helps and please respond to let us all know if it worked for your A3 also.
Old Oct 16, 2012 | 09:02 AM
JWP's Avatar
JWP
Worked perfectly.
s4str
A6 (C7 Platform) Discussion
9
Jan 23, 2025 04:22 AM
walsaadi
Q7 MK 1 Discussion
Jul 27, 2014 06:55 PM
Winston1
Oct 28, 2009 08:01 AM
CWTech
Jun 9, 2003 06:18 PM
SlvrBullet Unloaded
Apr 27, 2000 08:36 PM
