Audi A3 coding issues
Bought a new car and have had some problems with the navigation system "not on a digitised road" nav generally not working and today when listening to the radio a "fail" message displayed but if changing preset stations the radio works again momentarily - so borrow a VCDS cable off a friend and took a look around, I think I have some bodge after market changes... Ran an autoscan, results posted below, would appreciate any feedback on the coding/ errors... Many thanks.
VCDS Version: Release 11.11.3
Data version: 20120401
Monday,19,September,2016,13:57:02:32264
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WAUZZZ8P89A099254 Mileage: 126090km/78348miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 S HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 2917
Revision: --H09--- Serial number: AUX7Z0I0FNC05Q
Coding: 0000071
Shop #: WSC 06314 000 00000
VCID: 377735054656A51
1 Fault Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Mileage: 116426 km
Time Indication: 0
Date: 2015.12.13
Time: 20:33:34
Freeze Frame:
RPM: 924 /min
Speed: 3.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00000111
Temperature: 9.0°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 13422012092B0003C80D04E9901D00813800
VCID: 74EDC209D7A00E9
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047 B
Component: J255 Klima Man H07 0030
Shop #: WSC 00000 000 00000
VCID: 2F670D65BE066D1
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009274964
Coding: 15A82F81B0141380EF00001C0000000000084E156401040300 2800000000
Shop #: WSC 06435 000 08192
VCID: 489546F93BA8DA9
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06435
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499343FDE8A2231
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000882932CU
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000882072ES
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000048DE2B8Z
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000048DE2FF4
Crash sensor for front airbag; driver side:
Serial number: 35547RB400004A38C62P
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400004A38635K
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 41835BDD1892EB1
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2240I007013430
Coding: 0004428
Shop #: WSC 38586 067 57207
VCID: 3973333D7042B31
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K091130296
Coding: E9807F06400202002103
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 142
Mileage: 104806 km
Time Indication: 0
Date: 2015.02.27
Time: 18:28:03
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0I0FNC05Q
Shop #: WSC 27417 000 1048576
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 37: Navigation Labels: 8J0-035-192-RNSL.lbl
Part No SW: 8P0 035 192 P HW: 8P0 035 192 P
Component: J0503 RNS-LOW 0250
Revision: 00013000 Serial number: AUZ1Z1H8317464
Coding: 0042255
Shop #: WSC 00764 210 91830
VCID: 3C7D2A297F70869
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 176
Mileage: 104806 km
Time Indication: 0
Date: 2015.02.27
Time: 18:28:48
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000764
VCID: 438F51D5028EF91
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 232 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5D1A698F10169
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000764
VCID: 448D52C90780FE9
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Address 56: Radio Labels: 8J0-035-192-RNSL.lbl
Coding: 0042255
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 176
Mileage: 104806 km
Time Indication: 0
Date: 2015.02.27
Time: 18:28:48
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
VCID: 428154D11D94F09
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005060378
Coding: 0001422
VCID: 468948C131BCCC9
End ---------------------------------------------------------------------
