Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
engine break in
Old Mar 16, 2008 | 10:42 PM
schwartzw's Avatar
Default engine break in
I was just reading some posts at audiforums.com and in a break in thread a couple guys mentioned this link.
http://www.mototuneusa.com/break_in_secrets.htm
Seems to make sense. Has anyone else seen or given thought to this?
If all goes well I should be picking up my car in the next week or two so doing some research ahead of time.
Old Mar 17, 2008 | 02:16 AM
Deus Ex Machina's Avatar
Junior Member
Default Big controversy regarding this. The whole theory around break-in may not be as important as years..
ago, when the engine really needed a window to seat properly. That was when tolerances were not as close as they are now and manufacturing techniques were not as precise as now, either.
I personally like to go moderate. I don't "drive it like I stole it" because that sounds and is stupid.
I like to employ a deliberate, controlled moderate break-in by most importantly revving up and down the rpm range (close to redline) and letting the engine do the braking (slowing the car) by speeding up in 2nd to near redline and then rapidly taking my foot off the throttle and letting it decelerate while the engine vacuum pulls the piston rings into the cylinder walls, helping piston seating.
The manual (Audi at least) is not very specific as far as break-in. Just "don't drive more than 3/4 of the top speed on the speedo" and "don't rev the engine high when cold" and "don't use full throttle till 600 miles". Not alot of help but it does imply that the engine is pretty much broken-in and not a whole lot will mess it up now.
Old Mar 17, 2008 | 07:25 AM
April's Avatar
AudiWorld Uber User
Default ......
<ul><li><a href="https://forums.audiworld.com/r8/msgs/9430.phtml">klik</a></li></ul>
Old Mar 17, 2008 | 08:43 AM
Jack_Smackus's Avatar
Follow your manual.
Old Mar 17, 2008 | 09:00 AM
Bezor's Avatar
Tolerances are tighter, materials better, and so is the lubricant.
Old Mar 18, 2008 | 04:21 PM
OceanBP's Avatar
New Member
Default Best Answer seems to be...What leads to low oil consumption?
Some A3 owners complain of high oil consumption, like 1 quart per 1200 miles, roughly. Others don't. If there was a way to collect those owner who have the LOWEST consumption, and ask them how they broke-in their engine, it would be interesting info.
Personally, my '08 A3 2.0T now has about 800 miles on it. I have been watching the oil level carefully, always checking in my garage with a cold engine, for consistency. It hasn't budged from where it was when I brought home the car. (I'm sure it's not "zero" consumption, as that would actually be bad for the engine, if not impossible). My break-in process was just to drive the car like I normally would "in public," No redline (maybe once or twice...), essentially no full throttle, let the DSG trans decide where to shift, for the most part. Also, essentially no trips under 6 miles in length.
Old Mar 18, 2008 | 08:00 PM
April's Avatar
AudiWorld Uber User
Default There may be a fly in that ointment as some 2.0T engines appear to have valve guide
problems that lead to oil use. No function of the break-in process obviously
Old Mar 19, 2008 | 03:10 AM
TurboLust's Avatar
Junior Member
You should always check the oil while it's warm after having been at operating temp.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 20, 2008 | 05:50 PM
OceanBP's Avatar
New Member
Default Re: You should always check the oil while it's warm after having been at operating temp.
Not a lot of difference, in my experience. It will be slightly lower when at operating temp, soon after shutting off, because oil is still draining to the pan. But what I'm doing is consistent, and will tell me if it's changing levels - probably better than checking it hot, because when hot the level will vary a tiny bit due to just how much time has elapsed since shutting off the engine.
Actually, when cold, I'm just at the top of the top "full" notch, just like when new.
So it's all good.
acitrano
11
Dec 18, 2015 10:44 AM
ShaddowBlade
4.2 V8 Discussion
Feb 24, 2014 08:21 PM
kryzak
A4 (B7 Platform) Discussion
Jan 3, 2007 05:59 PM
JoeO
9
Feb 21, 2006 03:10 PM
DrGP
9
Apr 14, 2004 07:42 PM
