Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Help/advice please, engine diagnostic errors...
Old Jan 19, 2001 | 01:02 AM
Barnaby's Avatar
New Member
Default Help/advice please, engine diagnostic errors...
Just a quick question to see if anybody can shed some light on the following.
I took my 2001 S3 in for some work to be done under warranty, sticky/squeaking clutch pedal, condensation in fog lamp and loss of power from time to time when hammering it.
Basically, none of the work was done, except that the clutch pedal no longer squeaks, probably a drop of 3-in-1 - it's still sticky.
More worrying though is the report I have been given by the garage - the engine diagnostics has shown the following error - 16395, P0011 035 - Bank2, camshaft timing control Malfunction, sporadic fault.
What does this mean? They didn't seem too concerned so it got me thinking that perhaps it's the usual fob-off when the outcome is No Fault Found.
It sounds like a problem to me. Just wanted some other opinions/similar experiences.
Perhaps another tick in the crap dealership/crap service for Aston Green Reading.......
Old Jan 19, 2001 | 03:45 AM
AL B's Avatar
Default Re: Help/advice please, engine diagnostic errors...
Hi,
Well it sounds serious to me too, but I'm no engine expert! And your post is the first I've seen with a fault code documented.
But to tell you the truth, I think you've been pretty lucky in getting a report back from the dealer with the fault code on. I get sod-all from my local dealer.
I'd take the car to another dealer. I think Aston Green Slough is supposed to be better, but don't take my word for it - I live up north!
Seeing you've got the fault code, AmD might be able to give you some advice. Scott at AmD has a very good reputation as being one of the best Audi technicians.
Regards,
Alan<ul><li><a href="http://www.auto-amd.com">http://www.auto-amd.com</a</li></ul>
Old Jan 19, 2001 | 04:13 AM
Doug Ramage's Avatar
New Member
Default Re: What appalling service.....
When my S3's rear wash wipe failed, I rang my dealer (Simpsons at Lowestoft). They collected the car last Tuesday, sorted the problem (dislodged pipe), fitted a new DV (the original was starting to "puff"), valeted the car and brought it back to me.
Vote with your feet.
Old Jan 19, 2001 | 07:22 AM
AL B's Avatar
I do. Links at Macclesfield are great.
Old Jan 21, 2001 | 03:23 AM
Barnaby's Avatar
New Member
Thanks for the tip!
I have a home up North and down South so will probably check out some of the Northern dealers mentioned as per previous posts.
a4avant99
Jul 21, 2017 09:31 AM
cb95amc
Mar 22, 2006 12:53 PM
mm
19
Feb 28, 2004 05:46 PM
Ira B
Aug 28, 2003 06:54 AM
