Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
is this normal?
Old Mar 4, 2006 | 07:45 PM
An_A_car's Avatar
Default is this normal?
<center><img src="http://pictureposter.audiworld.com/97042/oil_cap.jpg"></center><p>Oil cap from my 4 month old A3. 10000 Kms, 1st oil change done at 8000 kms by dealer.
I cant tel if this is moisture or foam...
Old Mar 4, 2006 | 07:53 PM
Jack_Smackus's Avatar
I have never seen that before. I hear if too much oil is put into an engine it causes problems.
Old Mar 4, 2006 | 08:52 PM
daveak05's Avatar
Senior Member
Default Yes, it is normal...happens on most cars during cold months. It is...
simply moisture condensation due to the ventilated(pcv) oil system. You may even see it on the dipstick if car has been sitting for awhile in extreme cold. First time I saw this on one of my cars living in Lake Tahoe I freaked and ran around to a couple mechanics thinking blown head gasket. But, tuened out to be nothing. Goes away with weather change. Nothing to worry about.
Hope this helps.
Old Mar 4, 2006 | 09:48 PM
Timmay's Avatar
Default I'd freak too because I've never seen it either.
I guess I've never lived in a cold enough environment to have seen that happen.
Old Mar 4, 2006 | 09:54 PM
daveak05's Avatar
Senior Member
Default Re: I'd freak too because I've never seen it either.
I've seen it on my past cars(2001 jetta, 1997 ford f-150), and my Audi. It's usually confined to the oil cap and right below at top of engine. Even where you're at, if you live in southern cal, you may see it if weather is on the cold side and you haven't driven the car for several days.
Old Mar 5, 2006 | 01:06 AM
crew219's Avatar
Normal. Drive more and let the oil get completely heated up before you park.
Old Mar 5, 2006 | 04:38 AM
steveracer's Avatar
My 6000 mile 2.0t has this same crud. It is a concern for a new millenium design engine.
Old Mar 5, 2006 | 08:12 AM
An_A_car's Avatar
I drive 99% highway, hour long trips every time.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 5, 2006 | 10:36 AM
cpurick's Avatar
My God, it's full of stars...
Old Mar 5, 2006 | 04:55 PM
MisterJJ's Avatar
When you turn off the ignition, will it dream?
