Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Problem with central locking system
Old Jul 8, 2020 | 12:56 PM
MalyKros's Avatar
Default Problem with central locking system
Greetings,
I have recently purchased a 2006 Audi A3 2.0T FSI. The main problem is that the rear doors, both left and right, do not open or lock with the remote. Second problem: the alarm doesn't beep but lights blink when I trigger it by opening rear doors after I closed the front doors with the remote. Power windows work fine, as well as all the back lights on the handle switches like the window button. I have checked the fuses next to the steering wheel that were marked in manual as having something to do with doors/locks and they all look fine. I have done a lot of searches different forums that all suggest faulty wiring harness, or the door control module. One post I found in VW forums for a GTI said that the car had similar issues and it end up being wrong coding in VCDS door module and after someone posted the correct code, doors worked fine. Could some one more knowledgeable than me, please confirm I have right coding in my VCDS before I replace both control modules. I have attached full scan below. Thank you.
Thursday,2,July,2020,19:35:33:01197
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUNF98P46A042472 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
VIN: WAUNF98P46A042472 Mileage: 166580km-103508miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 B HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0080
Revision: --H10--- Serial number: AUX7Z0E6FNJ098
Coding: 0103010A1C070160
Shop #: WSC 09401 444 82758
VCID: 3169D9D3A82DF70EB4-8064
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 Q HW: 02E 927 770 AE
Component: GSG DSG 070 0926
Revision: 04507000 Serial number: 00000507070172
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 21492993F8CD478E24-8074
Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 R HW: 1K0 614 517 R
Component: ESP FRONT MK60-AT 0103
Revision: 00T12001
Coding: 0053890
VCID: 3663EACF4143D036E1-8062
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 K HW: 8P0 820 043 K
Component: KlimavollautomatH17 0200
Revision: 031182 Serial number: 8P0820043K
VCID: 3467D0C7573FC226DF-8060
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 10
Mileage: 165594 km
Time Indication: 0
Date: 2019.10.08
Time: 11:50:34
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002099155
Coding: 618C5F80C014100000181800180000000028FE175C1200
Shop #: WSC 06314 123 08192
VCID: 408F8C1713876E864B-8014
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H10 3250
Revision: 91H10325 Serial number: 0035W0005L2P
Coding: 0032705
Subsystem 1 - Part No: 8P0 910 339
Component: BF-Gewichtsens. 01 0020
Serial number: 6332DRB401FD0F22V
Coding: 00032705
Subsystem 2 - Serial number: 6342DRB401FD0610K
Subsystem 3 - Serial number: 63528RB4007E67F9
Subsystem 4 - Serial number: 63628RB40080ABC0M
Subsystem 5 - Serial number: 63729RB40093E15BQ
Subsystem 6 - Serial number: 63829RB40093E142H
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0014142
VCID: 41898913188D678E44-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 E HW: 8P0 920 981 E
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2246ED03002384
Coding: 0000403
Shop #: WSC 65431 000 104857
VCID: 3A7BFEFF755B345605-806E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105715888F
Coding: 7F3F03C8072102
VCID: 2A5BCEBF85FB84D675-807E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0E6FNJ098
Shop #: WSC 00000 000 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 C HW: 8P0 035 192 C
Component: RNS-E US H70 0260
Revision: 01S Serial number: AUZBZ7E1900537
Coding: 0209617
VCID: 2F6DDFABBE19E1FEA2-807A
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0001177
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326BD6DFAD2BCC16CD-8066
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 D
Component: 02 KSG H04 0050
Coding: 9AC003382D2C8F0FC80F447300
Shop #: WSC 06314 123 12345
VCID: 3D71F5E36475036E20-8068
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0001177
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Revision: 00000000 Serial number:
Coding: 0000001
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209617
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0001176
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
002 - Lower Limit Exceeded
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0001176
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 B HW: 8P0 862 335 B
Component: FSE_255x BT H18 0160
Revision: 00000001 Serial number: 00000000269974
Coding: 0011477
VCID: 3561EDC35C45DB2EE8-8060
End-------------------------(Elapsed Time: 02:05)--------------------------
File Type: txt
cleo8101
VAG-COM Discussion
9
Oct 27, 2023 08:33 AM
awss4
VAG-COM Discussion
Aug 24, 2013 06:05 PM
Quattro4me2006
VAG-COM Discussion
Feb 11, 2012 11:15 AM
CSavage
VAG-COM Discussion
14
Nov 28, 2011 09:44 AM
Bridgetown
VAG-COM Discussion
Apr 10, 2009 07:54 PM
