- Audi A3 Why is Power Window Not Working<br>Guide to diagnose trouble and recommended solutions.
Window Switch not working Help Please
Thanks for the help.
Press and hold the window-down switch until the window is all the way down + 10 seconds. Then do the same thing in the 'up' direction. Then power-cycle the car and try the auto open/close again.
If it doesn't work the first time, people said to repeat the process. This must be done whenever the battery is removed and replaced.
You try to raise a lowered window, but it actually drops further...THEN, it raises on the second attempt? My driver's side-rear window does this. No big deal—just weird.
yes your switch botton is damaged you have to replace it
