Audi A3 / S3 / RS 3 MKIII Discussion forum for the 2022 and up Audi A3, S3 and RS3
Continuous rattling noise A3 8Y Sportback (dashboard rattle?)
Old Jul 18, 2022 | 01:45 PM
G86's Avatar
G86
Default Continuous rattling noise A3 8Y Sportback (dashboard rattle?)
Hi everyone, since December 2021 I have a new Audi A3 8Y Sportback Advanced 35 TFSI S-Tronic MHEV and since March/April 2022 (so since a few months) I have a very disturbing rattling noise that presumably comes from the passenger side of the dashboard.
I also have the feeling that the rattling noise is more persistent when it is hot outside. Also, I only hear this when I drive straight or when I steer to the right. When I steer to the left, the rattling noise is completely gone.
I have attached a sound clip: you hear the rattle noise continuously for 30 seconds. Is there anyone who has an idea of the reason and the solution?
Because I first find out before going to the dealer who may prefer to be deaf to solve the problem.
The Audi currently has 15,000 km on the odometer.
Thank you!
File Type: mov
Old Jan 13, 2023 | 09:36 PM
Audi8ya..'s Avatar
Default Rattle noise
Is there allready a solution? I have the same noise
Old Jun 27, 2023 | 11:57 PM
yippitykip's Avatar
Hey guys.
Any solution to this? My rattle is completely identical, can't pinpoint it.
Old Jul 26, 2023 | 11:33 PM
JonasF's Avatar
Did you guys get this sorted? I think I have the same noise from front left side.
Old Aug 2, 2023 | 11:00 AM
Economist's Avatar
I have an 8Y RS3 and had the same issue, including my door panels. One dealer fixed the door panels but I had to try a few other dealerships to fix the rattles that were coming from my center console since they were trying to blame my straight pipe exhaust even though this issue started around 3k miles with the OEM exhaust. Finally got another dealer to fix the center console rattles under warranty. They had to remove the center console and add lots of felt to different locations within the center console. The noise is now gone thankfully. I have other friends with 8Y RS3s and about half of them have issues with rattles and half dont. I also had a loaner A3 with 10k miles and that one didnt have any rattles, so it seems to vary from car to car. My guess is the ones that dont rattle now, will rattle eventually, especially on the stiffer suspension cars like the S and RS models. Hope that helps!
Old Aug 25, 2024 | 01:39 PM
raf929994's Avatar
did you manage to solve the problem of this sound?
Old Sep 1, 2024 | 10:18 PM
MingusDew's Avatar
You can use a tone generator on your phone to play different frequencies and turn the stereo up to see if you can induce the vibration while sitting. You need to start popping panels off, and seeing when rattle goes away. Inspect the panel, find place where it is rubbing, and use felt tape where it fits or use silicon grease to lubricate the contact spot. It’s trial and error. I’d suggest starting with the dash speaker grills if you have dash rattles.
FindTape Polyester Felt Tape [1mm thick] (FELT-06): 3/4 in. x 75 ft. (Black) https://a.co/d/bIq8Pas
Yotache Foam Strips Adhesive 1/16 Inch Thick x 1 Inch Wide, 1.5mm Close Cell Foam Rubber Weather Stripping Tape Seal for Doors Insulation, Total 33 Feet Long https://a.co/d/dWtmw6E
MILEQEE Single-Sided Adhesive Foam Tape Low-Density, Super Soft Easy Adjust Sealing Strip for Window Door Air Gap, Sponge Draft Blocker and Sound Reducer, 1.18in x 6.6FT Black https://a.co/d/4ZaFerH
Super Lube 92003 Silicone Lubricating Grease with PTFE, 3 oz Tube, Translucent White https://a.co/d/42P3Tec
Old Apr 27, 2025 | 11:17 AM
raf929994's Avatar
in what cases did you hear this sound? depending on temperature, speed, driving over bumps?
Audiq5s
Q5/SQ5 MKII Discussion
Jun 7, 2021 12:02 AM
Rey TTS
TT (Mk2) Discussion
Oct 16, 2017 10:03 AM
sinned
Sep 13, 2004 04:58 AM
cdagza
Jul 14, 2002 04:01 AM
s4hon
Apr 9, 2002 07:12 PM
