Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
My Guess: Audi RS5 5.2 V10 FSI Valve-lift N/A with 480 hp.
Old Feb 17, 2008 | 11:09 AM
  #11
crespo's Avatar
V8TT will weigh more than a V10... and won't sound as good
Old Feb 17, 2008 | 01:24 PM
  #12
acadia1's Avatar
Default I'm pretty sure the v10 will sound better (higher displacement, more sound). For weight, as stated,
let's see first. What do they weigh now?
Old Feb 18, 2008 | 12:45 PM
  #13
B.S.Rick's Avatar
Member
too big!
Old Feb 19, 2008 | 07:03 AM
  #14
RI A6's Avatar
Default How can the V10 not be heavier than the V8?
The the S5 and the RS4 V8 already are pretty darn light. Add 2 more cylinders/pistons/rods and the associated lengthening of the crank and block, and it would be hard to believe that weight did not go up. Of course, the turbos and plumbing would add additional weight, but the designers would at least be able to place them further rearward for better weight distribution.
Having said that, I'd love to have a high revving NA V10 in the car. It would just be a bit tougher in the corners.
Old Feb 19, 2008 | 11:37 AM
  #15
acadia1's Avatar
Default Same question as intuitively would think a feather and penny fall to the earth at different rates.
To answer this question you'd have to look specifically at those two engines. It's not as though the v10 is simply the same v8 engine with 2 more cylinders attached.
Old Feb 19, 2008 | 12:27 PM
  #16
The Pretender's Avatar
Default Re: How can the V10 not be heavier than the V8?
The High rev 5.2 V10 FSI will have a lot of light weight internals to keep the weight low.
Jarod.
Old Feb 19, 2008 | 12:58 PM
  #17
RI A6's Avatar
Default well ... actually, I'd calculate the V10 to be about 48 lbs heavier.
The V10 has exactly the same cylinder pitch and spacing as the Audi V8 and V6 engines, thus the block size has to be extended by approximately 25% over the V8, thus there are 2 more sets of pistons and rods, thus the crank must be approximately 25% longer.
Both blocks use Alusil and are manufactured by Kolbenschmidt.
However, having said that the published weights (from Audi Service Training Manuals) for these engines are:
Q7 V8 - 437 lbs with Automatic Transmission
RS4 V8 - 467 lbs with Manual Transmission and dual-mass flywheel
S6/A8 V10 - 485 lbs with Automatic Transmission
The Q7 and the S6 both use a 09 Tiptronic transmission, but with different gearing ratios, thus the different designators 09E for the S6 vs. 09O for the Q7. Thus, we can use the RS4 engine as a fairly good gauge for weight difference between the Manual and Automatic transmission. If anything, any lightening of the RS4 engine will decrease the differential, where the automatic transmission is 30 lbs lighter than the manual.
From this we can compute the probable weight of the V10 with a manual transmission (assuming the manual transmission does not have to be modified to handle the additional torque) to be 515 lbs, or about 48 lbs.<ul><li><a href="http://www.rheinmetall.de/pdfdoc/praesentationen_ir/englisch/atag_engl.pdf">Alusil Blocks</a></li></ul>
Old Feb 19, 2008 | 01:10 PM
  #18
RI A6's Avatar
Default Not really. There are few places that weight can be reduced if the RS4 is typical
Here are the lower weight items used on the RS4:
Intake Valves and Valve springs
Connecting Rods
Simplex vs. Roller Chain
Magnesium Intake Manifold
Crankshaft weight was increased with a dual-mass damper in RS4 for counterbalance ... "heavy metal inserts are integrated in the first and eighth crank journals by way of unbalance."
My calculations below include the weight savings from the RS4 in a conservative estimate. No matter how you cut it, a V10 manufactured with the same block technology, at the same cylinder bore and spacing, has to be heavier than a V8.
Old Feb 19, 2008 | 01:28 PM
  #19
RI A6's Avatar
Default And ... yes, the V10 and V8 are quite similar engines
The V10 and V8 have the following identical specs:
Bore - 94.5 mm
Stroke - 92.8 mm
Cylinder Spacing - 90 mm
Cylinder Bank offset - 18.5 mm
Compression Ratio - 12.5:1
Block Alloy - AISi17Cu4Mg
Overall Engine Length V10 - 560 mm
Overall Engine Length V8 - 464 mm
Old Feb 19, 2008 | 02:39 PM
  #20
RI A6's Avatar
Default 220kg = 485 lbs with Tip, 515 lbs with Manual
The "light weight" parts will generally be in the rotating elements, like pistons, rods, valves, and valve springs, where the difference in weight is measured in ounces.
A V8TT would, of course, have added weight from the turbos and plumbing. However, I doubt it would be the additional 50 lbs that the V10 weighs, and I would hope that the mass could be positioned further back.
Having said all this. A high revving V10 would be an awesome beast!
I'm also not sure why Valve Lift would be placed into a high performance engine, with it's emphasis on fuel economy at the expense of more moving parts.
ACSGP
Jun 5, 2007 09:00 AM
no.radar
Audi R8
Jan 13, 2007 05:53 PM
B.S.Rick
Audi R8
Aug 23, 2006 08:45 AM
BrabusS55AMG
Aug 31, 2004 03:34 PM
xr8edS4
Sep 4, 2002 04:14 PM
