Wheel Stud Bolts Stripped
http://www.andysautosport.com/audi/2...eel_studs/h&r/
I had a similar occurence at the track a few years back - noticed on the warm up lap that I was getting a horrible vibration from the front end. Luckily I was able to get off track without incident and found that the bolts on one of the front wheels had worked loose (but not fallen off). Luckily no damage to the hub - so I was able to retorque and head out again. This occurred on the 4th run of the day and I know I had checked torques in the morning, so lesson learned: check mounting bolt torques before each track run. But on the street I have never had an issue with bolts that were properly torqued working loose.
It may be possible to clean up the threads in the hub, but I would suggest taking the car to a professional repair shop. You may find that a new hub is the best approach, to ensure no long term issues.
