402 mod help
Old Nov 9, 2007 | 06:22 PM
JeffK95z's Avatar
Default 402 mod help
Hey guys,
Just got my vag-com cable for my new 02 allroad (woohoo!) and i'm trying to play with the 402 mod...
But when I goto 'login', it fails with 'login lost due to dropped session'.
From the research that i've done, it seems the login code is incorrect. Based on the documentation on ross-tech's site, the login code to use is 31564
can anyone confirm success/failure with this as well?
Thanks!
jeff
Old Nov 9, 2007 | 06:53 PM
Rally_nutcase_1982's Avatar
Senior Member
Default here you go....
<ul><li><a href="http://www.allroadfaq.com/howto/vagcom.shtml">http://www.allroadfaq.com/howto/vagcom.shtml</a</li></ul>
Old Nov 9, 2007 | 06:58 PM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
Default Yea it's a big PITA
Once the login is dropped, you need to turn the key off and then back on before you try again. When entering the actual values, you will have to do it as many as five times to get through all four wheels without getting an error. I've also found that you'll have the best results with the key on but the engine off. You have to turn the key off every time it fails and there is a hard limit of a couple minutes to do the entire procedure.
Old Nov 9, 2007 | 07:01 PM
AudiWorld Uber User
25 Year Member
Default Oh I almost forgot
once you begin the procedure, it clears the home position. You MUST complete the procedure successfully before you can drive your car again. Also it's pretty important for your car to be as level as possible when you do this.
Old Nov 9, 2007 | 08:20 PM
paulroad's Avatar
Tech Guru
Default turn off any screensavers on your laptop.
I had this problem years ago. The screensaver disconnected the cable port so the session went out.
Old Nov 9, 2007 | 09:36 PM
JeffK95z's Avatar
Default Re: here you go....
thx for the info guys...
Nutcase - thats the doc I used as well, it just kept dropping connection when @ the login step.
I'll try again with the input here!
cheers,
jeff
Old Nov 10, 2007 | 06:22 AM
Senior Member
Default Check your task bar, disable all Anti-Virus tasks and what ever else you got running
Very unlikely that you'll catch a virus from your car ;-)
Any process or program running on secondary scheduler could interfere with it, just shut those down (Ctrl/Alt/Del - task manager). And what Paul said, screen saver as well.
Also start the car when doing the 402 to ensure 12 Volt feed to the cable. Uwe (Ross) told me some years back that this could contribute to failure, you need at least this voltage.
Old Nov 10, 2007 | 07:31 AM
Screen Name:12345's Avatar
What version of the software are you using?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 10, 2007 | 11:31 PM
JeffK95z's Avatar
Default Re: What version of the software are you using?
Sorry, should of stated hardware/software versions:
VAG-COM 704.1 with an offical cable from Ross-Tech. (Just purchased last week)
Windows XP w/ SP2 and all updates
I am able to log data from the car, and such, it was just the login part that kept failing.
I'll play around with this tomorrow, but as an aside, today was the first real road trip in the car (only got it a few weeks ago) drove down the I5 from canada to crazy seattle outlet shopping
The allroad was awsome! Great passing power, super stable at decent speeds (100 mphish) and pretty comfy for all 4 of us! Both my wife and I are really pleased with our purchase!
Old Nov 12, 2007 | 05:27 PM
JeffK95z's Avatar
Default Update - with fault codes
An update... I tried this today using all suggestions everyone posted, but unfortunately no luck.
It constantly displays the login lost message.
However, I did a full scan and found the following 3 codes, is it possible they are causing some of my grief?
00776 - Level Control System Sensor; Left Front (G78) - 57-00 - Electric Circuit Failure
01771 - Control Module for Headlight Range (J431) - 79-00 - Please Check Fault Codes
00776 - Level Control System Sensor; Left Front (G78) - 31-00 - Open or Short to Ground
Now, from the research I've done, I've found the following:
Power for the left-hand leveling-system sensors (-G78- and -G76-) is supplied from control module -J431- of the headlight range control system.
This leads me to believe that J431 is bad and the other 2 codes are due to this.
Also, check out this picture, and note the Component codes. The pdf doc shows code X031 where-as mine shows up as X040. Any idea if this is a problem? (sorry, can't figure out how to post pictures within posts)
http://i15.photobucket.com/albums/a351/JeffK95Z/402_disconnect_login.jpg
