402 - when to measure height?
It appears that my suspension doens't really maintain consistent levels. I successfully performed 402 mod, lowered the front end by 2 cm (422 values), and the rear by 1 cm (412 values), did the save procedure.
As I drive and park, the front left can be higher or lower, same with the rear. It's as if the suspension is parked at different levels.
The compressor does not kick in, there are no leaks. If I measure the front wheels, they will differ from each other, then after I drive, teh values will be different yet again.
Thanks.
Even if you do notice a difference in ride height after your coding, there will always be that error span to the values you enter at each corner because of the leveling sensors not being exactly precise.
I dont know if you can understand that ahah
