Air susp compressor survey....How often does it cycle?
Old Aug 26, 2017 | 05:00 AM
  #21
amiram's Avatar
Originally Posted by Kevin Musai
I have the same problem the check suspension light comes on and with vcds scan tool it shows this fault code 02646 plausibillity of level control system i checked in the service for leaks with water and soapy test it have no leakage can anyone help me ?
In most cases there is a leakage phase that is called only in motion. A pressure leak can be also from air connections on the valve block end from the air spring air connections . (1 in the front and 3 on rear). Is the air springs are original or ...
Old Aug 30, 2017 | 12:29 AM
  #22
Kevin Musai's Avatar
The air springs are original but i notice that the left side of the car both front and rear left suspension are a bit lower than right side of the car
Old Aug 30, 2017 | 04:47 AM
  #23
amiram's Avatar
Do you have a VCDS or a professional scanner? If so, go to the basic setting and see the height of the four corners. Park the vehicle on a straight area (level),Be sure that the tires pressure is correct. Measure from the wheel center to wing. Is the height difference between left and right fixed ? (even after night) What is the production year of the vehicle
scottmiller
Audi A3 / S3 / RS 3
Jul 7, 2016 05:27 PM
B5S4toD3A8
Sep 8, 2004 06:21 PM
S4IT
9
Apr 11, 2001 12:59 PM
