alarm problem
Old Jul 10, 2002 | 05:31 AM
dstitz's Avatar
New Member
Default alarm problem
In the past month, my alarm has decided to go on and off at random times after parking and locking the car. The only time I can be assured that the alarm will not activate is if I press the interior movement sensor prior to locking the vehicle. Note: The alarm has triggered without my dogs in the car.
Anyone else experiencing this problem?
Old Jul 10, 2002 | 05:38 AM
QQQQuattro's Avatar
Any windows/sunroof open when you lock it? If so, wind could set it off. Otherwise, needs service.
srs's Avatar
srs
Mine activates with a moderate breeze if any window (or the roof) is open at all
Old Jul 10, 2002 | 05:40 AM
frau_allroad's Avatar
New Member
Default Re: alarm problem
Mine does it also, but only if I have left the windows open. Apparently it has to do with air motion (see discussion about this below).
Highly annoying. I recently had the sensitivity adjusted, and it is still doing it! Hate locking up the car so tight in the hot weather, just so the alarm doesn't go off.
Old Jul 10, 2002 | 06:11 AM
RobSo's Avatar
Default I went through the same problem with my S4..
I took my car to the dealer asking them to lower the sensitivity of the motion sensor. I verified with my vag-com that they didn't do a thing. Bastards! Anyway, what you need to do is lower the sensitivity value to 50 from 99. It worked like a charm for me. Just find a person local to you with a vag-com. It's a 2 minute process.
Rob
Old Jul 10, 2002 | 07:43 AM
JBo_53's Avatar
Junior Member
Windows open-alarm goes off.. windows closed-no problem
Old Jul 10, 2002 | 08:08 AM
RobSo's Avatar
Default My alarm used to go off 3-4 times a day with the windows closed. BTW,
do you notice your apr catback getting louder with use? Seems like mine are, ever so slightly.
Old Jul 10, 2002 | 11:22 AM
HPH's Avatar
HPH
Default Can't have it both ways.
The motion sensors are sensitive intentionally. Although you can reduce the sensitivity, per above posts, with the VAG-COM tool, that reduces the effectiveness of the alarm system.
The button on the door frame is to turn it off when you want to leave a window open (or leave a pet in the car or whatever).
It !might! be possible to reverse the sense of that button with the VAG-COM tool, to use it to turn the system on. I don't know about this, but someone with the tool might. HPH
oesman
A4 (B9 Platform) Discussion
Apr 22, 2017 04:01 PM
charris
May 18, 2008 07:28 PM
GVee
Jul 8, 2006 05:35 AM
JimOB
Jul 7, 2000 04:38 PM
Auditude
May 14, 2000 01:28 PM
