Alignment question....
Dave
While I would not suggest Sears, I would look at a good independant shop. As on the area forum where you live for suggestions.
Personally I've gone to Marios Tire and Alignment on Rt 21 and Emmet St. In Newark. Its not sketchy..all he does is tires and alignments on good Hunter equipment. Make sure you put the car in Jack mode.
They do, however, set the alignment in level 2 and then look at it again in level 4. I'm sure someone else has the proper description. It is apparently more complex than a normal car to do properly due to our fancy suspension.
All that being said, it's always worth talking to a good indy.
Cheers
Gregor
Find a German with a heavily modded allroad to even it up for you.
