AM Reception problem.
How can I daignose what the problem is without taking down the headliner and looking at the base, the wire the diversity switch etc. (I have a VAG)
It could be the base, it could be the diversity/switch set up. I just want to track it before I open up the headliner.
If you hit the door's lock button, you hear the elecrical surge on the AM.
A note of caution, if you remove the base, its designed in such a way that it can be secured flush to the roof and have wires running through it. It uses a special kind of nut and a spacer with a notch in it. Just be sure not to pinch the wires when tightening the base. all of the wires should flow through the small notch in the front of the spacer...you'll see what I mean.
Here is the inside and underneath of the base. The AM antenna wire is soldered to the verticle chip from underneath:
<img src="http://pictureposter.audiworld.com/81343/2006__1156.jpg">
<img src="http://pictureposter.audiworld.com/81343/2006__084.jpg">
Here is what the base looks like. One of the two wires connects to the AM antenna wire:
<img src="http://pictureposter.audiworld.com/81343/2006__1189.jpg">
Here's how to get to the base, and I didn't need to pull back the headliner:
https://forums.audiworld.com/allroad/msgs/101864.phtml
Hope this helps.
