Cat Problems
Old Feb 27, 2010 | 01:26 PM
winewino's Avatar
Default Cat Problems
HAving trouble with the cats on my '02 Allroad 2.7 , 6 speed Bi-turbo. Mechanic scanned it and it came up 421 and 431. Now , apparently, the only aftermarket cats, reasonably priced are for an automatic tranny.(????) does this make sense? We checked the dealer and they want around a thousand a piece.
Any advice will be greatly appreciated.
Thank you.
Old Feb 27, 2010 | 01:46 PM
thejulex's Avatar
Get yourself a set of Piggie pipes from vastperformance.com, these are stock cats with gutted pre-cats and relocated o2 sensors. You will gain a bit performance and the check light will be gone.
Thanks.
Old Feb 27, 2010 | 04:32 PM
Benzie's Avatar
Default cats -
Not sure if this info will be useful to you, but I had a bad cat that kept giving me a check engine light. I went and had it replaced at an indy shop, and I still had the same problem. I later discovered that they used an aftermarket cat...so I had them replace it with an OEM part. I had no problem after that...and both the aftermarket and the OEM cost about $1,100.
Old Feb 27, 2010 | 08:02 PM
paulroad's Avatar
Tech Guru
did you know you cats ar guranteed for 8/80 from the date of purchase regadless of the number of owners. How many miles on your ride? is it less than 8 years? even 1 day less works.
Old Feb 28, 2010 | 07:52 AM
Benzie's Avatar
Default cats
By 8/80 you mean 8 years or 80k miles? My '02 had 135k at the time.
Old Feb 28, 2010 | 08:24 AM
paulroad's Avatar
Tech Guru
correct..EPA major component coverage is 8 years or 80k miles. It covers the cats and the ECU/OBD only.
Old Mar 1, 2010 | 05:32 PM
winewino's Avatar
Thanks.
Thanks for the info, I'm looking into it.Do you know if these will fit an Allroad with a 6 speed tranny. Apparently , the mounting is different on the cats for an autmatic.
Old Mar 1, 2010 | 05:54 PM
paulroad's Avatar
Tech Guru
vast will sell you exactly what your car needs or he will remanufacture your own parts.
Old Mar 1, 2010 | 08:13 PM
vponomar's Avatar
Paul, you have an RS6 cat-back, but no piggie pipe? How come?
dwitzel
Oct 9, 2009 05:00 PM
SKBrown
Mar 6, 2009 01:36 PM
crusininda944
Audi 100 / A6 (C4 Platform)
14
Aug 19, 2008 03:04 PM
Jim Bush
Sep 21, 2007 06:26 AM
wclepse
Mar 9, 2005 04:50 PM
