Changed the temp sending unit
Old Feb 28, 2008 | 10:06 AM
dejavu's Avatar
Senior Member
Default Changed the temp sending unit
Level of difficulty, 2 out of 10. Parts were $30 at stealership or $14 from Carson. If your coolant temp needle jumps from normal to cold constantly, your sending unit is going bad.
The unit is a bit difficult to access so you'll need to remove some of the hoses.
Temp sending unit is the green plug. Consult the tech articles for a detailed writeup.
<img src="http://pictureposter.audiworld.com/27121/tempsender.jpg">
Close Up
<img src="http://pictureposter.audiworld.com/27121/tempsenderii.jpg">
Old Feb 28, 2008 | 10:48 AM
dscottjr's Avatar
If you're under 100k miles audi will change it for you or reimburse you for your troubles;-)
Old Feb 28, 2008 | 10:53 AM
dejavu's Avatar
Senior Member
Default really? I wish the parts guy told me that.
is there something in writing?
Old Feb 28, 2008 | 11:00 AM
paulroad's Avatar
Tech Guru
Default YES.... all allroads and A6 2000+ were given a 100,000 mile
warranty on this specific part. The letters started going out from AoA last week to all listed owners. Just drive into the dealer and say..please fix it under the extended warranty.
Old Feb 28, 2008 | 11:29 AM
dejavu's Avatar
Senior Member
Default just remembered that when I called to check for the part
the parts guy said that they just recieved 40 sending units in. Should have raised an eye brow.
Old Feb 28, 2008 | 11:30 AM
Misplacedyankee's Avatar
The letter had a reimbursement form if you want your $14 back...
Old Feb 28, 2008 | 12:18 PM
dscottjr's Avatar
Default I think i threw mine in the garbage but i'll look tonight for you. It should be posted on a nhtsa
site or audi site. Maybe someone that has it could scan it and put it on here?!?
Old Feb 28, 2008 | 12:22 PM
dscottjr's Avatar
Default Here's the letter. It's the same as this one only for audis, not vws:-)
I couldn't find the rebate form.
<a href="http://img249.imageshack.us/my.php?image=vwletter1sc9.jpg" target="_blank"><img src="http://img249.imageshack.us/img249/2906/vwletter1sc9.th.jpg"></a>"
<a href="http://img249.imageshack.us/my.php?image=vwletter2fn3.jpg" target="_blank"><img src="http://img249.imageshack.us/img249/3581/vwletter2fn3.th.jpg"></a><ul><li><a href="http://forums.vwvortex.com/zerothread?id=3694323">http://forums.vwvortex.com/zerothread?id=3694323</a</li></ul>
Old Feb 28, 2008 | 12:28 PM
dejavu's Avatar
Senior Member
nice. I'll do a search myself. thx
MikeNSX
Nov 1, 2010 02:24 PM
Bezor
Audi A3 / S3 / RS 3
Mar 4, 2009 03:06 PM
Just Me
May 9, 2008 04:33 PM
falcindor
NY / NJ / CT Discussion
Jul 3, 2007 10:37 AM
NDA4
Jan 7, 2002 09:31 AM
