Chip upgrades
Any info would be greatly appreciated.
"If you have a Tip, make sure to get a chip that limits torque to less than 310/320lb ft. AMS/abt has destroyed two Tips ( $7000 each ) in engine testing to determine safe torque levels."
"The chip maker with the least problems was AMS. Unlike some other brands mentioned, I have never seen an engine or transmission failure with an AMS chip. They always test the chip in the real world in a controlled fashion before releasing it to the public. There are no upgradeability issues ( free upgrades ), because the chip is complete and does not need to be tweaked at a later date. If they do have a failing, it is being slow in getting a product to market because they perfectionists. I can go on at length about details of all the different chips out there, but AMS seems the most conscientious with regards to dealing with someone else's car."
I want to chip my ar, but have decided to wait awhile to see more longterm info on reliability of engines that are chipped.
Good luck with your research.
Just imagine. If the air is thinner, but the turbo/boost controller is looking for a certain psi, the turbo has to work longer and harder to try and get the boost. In the end, turbo life is reduced.
