Coolant Temp Sensor CEL
1 Fault Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-00 - -
Readiness: 0000 0000
So I changed the coolant temp sensor under the flex intake pipe. The original one was green and the new one was green as well. Still got a CEL and same fault code. Any ideas? Maybe the new temp sensor is bad as well?
thanks
The switch in the lower hose is for the cooling fan .
