egt sensor delete done!
Old Feb 23, 2009 | 02:27 PM
choptt's Avatar
Default egt sensor delete done!
i figured a way out of removing the sensor but keeping the ecu fooled to thinking the temp is 945c at all times,
i wonder if i should make a few?
Old Feb 23, 2009 | 02:53 PM
gragravar's Avatar
Default can you do this to other sensors?
like the ride height sensor? You could sell lots more of those to people with coil conversions.
Old Feb 23, 2009 | 02:57 PM
choptt's Avatar
Default Re: can you do this to other sensors?
i will look into it, probably pretty easy.
ive got a TON of info that will be avaible in the near future, some of it will be posted up here,some of it will be avaible on my website.
Old Feb 23, 2009 | 03:01 PM
cfdarch's Avatar
New Member
website address is?
Old Feb 23, 2009 | 03:17 PM
choptt's Avatar
Default won't be up for a little
sorry,
i have it, but i haven't published yet.
Old Feb 23, 2009 | 03:48 PM
autosolutions's Avatar
Default Why would you want this? The egt sensors protect the motor from leaning out & melting things
I would think the ecu would have picked up on the fact that cold start & 975* temp instantly was not possible.
Old Feb 23, 2009 | 05:08 PM
04 allroad's Avatar
Concur
Old Feb 23, 2009 | 06:06 PM
skidmark's Avatar
Default 945 is as low as the sensor ever reads. It's a safety feature for sure, but many remove the n249
which is also a safety feature. I wouldn't remove either, but to each their own.
Old Feb 24, 2009 | 02:56 AM
choptt's Avatar
Default 945c, and for 600-700 dollars
for the egt sensors, sold in pairs only now, and german car parts no longer can get them, leads me to no care if i melt an 02 sensor. rember, the egt sensors are just for temp, but the 02 sensors control your a/f ratio. there are a few 1.8t with egt sensors, but a vast majority don't have them,with Big turbos runing 25+psi on stock 02 sensors with no issues.
its just a BS sensor that cost an arm and a leg that is really not needed.
Old Feb 24, 2009 | 04:48 AM
Chaddy's Avatar
Junior Member
Default I replied in the B5 forum, but please be aware that high EGTs will kill a lot more than just O2....
....sensors - things like exhaust valves and valve seats, etc.
